iPhone Cable
iPhone Cable
So just realized my new-to-me car came without a cable...I looked at many of the threads on here were people recommend leaving an old iPhone plugged in (great idea...going to dig one out from the junk draw). However before I get there any recommendations on cables? The ones on Amazon don't get great reviews and I don't want to drop $70+ on an "Audi" cable...that's just crazy lol!
Most of the negative reviews come from people not understanding what the cable actually does or how it's supposed to operate. A lot of the cables will only transfer the music information but won't charge the device at the same time, the AMI wasn't really designed to act as a charger (from my limited research). These people then tend to blame the product when it's a limitation of the system its connected to.
Perfect example is I use an AMI to female USB cord (bought on Amazon), have music files stored on a thumb drive and use this to play the music on the AMI, works great! But the thumb drive didn't have enough space for my whole music collection, so I bought a SSD (1TB) to put more files on, but the AMI doesn't have the power capacity to drive this, so back to the thumb drive I go....
I may be wrong, and I am sure I will be corrected if so, but this is based off a little reading and my own mini-experiment...
To get an iPhone to work, the way you are expecting, you need the cable model number 4F0051510AL. As far as price, shop around. As I type this, I'm seeing right now from an alternative seller on Amazon, cable 4F0051510AL, for $45 and $5 shipping. On eBay, I see one in an OEM package, for $25, you pay shipping.
I'm sure someone has tested it (hint I haven't searched for it) but if you powered the SSD (1TB) separately, it might work.
Originally Posted by thiefa4
You're trying to get your whole library recognized. Interesting, I was wondered why you weren't using the SD card readers in the car, since they each can reportedly support 64 GB cards, and your prior photo showed a 128 GB thumb drive.
I have considered externally powering the drive to make it work, this is all just me playing around with it and seeing what I can and can't do, I have to admit it would have been great to have my whole collection at my fingertips and ready to go, by simply plugging it in!
FWIW, variously:
1. The cleanest sound is probably direct from the SD cards in the slots. IIRC that avoids a layer of filtering all other device connections have.
2. If I were thinking a USB drive, I would first just look at using the slots. A reader on the laptop side costs very little--if it doesn't already have the slot--and the media holds enough for all but the really large libraries.
3. From the screen shots I have seen, juxtaposed with occasional experience with Bluetooth connecting, a weak spot relative to cabling in with a supported device is likely the general MMI interface, particularly when switching or closing albums. If you do it by playlist, probably not a biggie. Otherwise, I think you back into building a folder structure organized around the way you like to access music/content.
On some other posts, to be clear a slave device like an old iPhone or iPod charges 100% reliably. Even ones that are many years old with presumably weaker batteries still work fine for me. If the device is newer/supports iOS changes back a lot of years now, it should also be able to sync the music library automatically from iTunes--if your parking spot reaches your home wi-fi.
Thanks MP4. I may go the SD card slot direction....it seems crazy to pay $25+ for a cord to power my phone after I've thought about it. I've already got a 12V charger that I can plug my phone into. Bluetooth connection for audible is fine and I can download hi-def files onto two SD cards and load to the jukebox
