OBDEleven
#21
So I tried to change the parking camera from 5 mph to 20 mph. When I go into the Swithc-off speed for parking assist it says Function canceled, marginal conditions have not been met. Any ideas? The car ignition is on but the engine is not. I can change other settings in the long code sections
Parking camera stays on until roughly 20mph:
- (A5) Front Sensors Drivers Assistance System
- Switch-off speed for parking assist
- Old value - 10 km/h
- New value - 30 km/h
- Press and hold green check mark to save.
#22
So anytime I go to (A5) Front Sensors... screen it sticks at "loading data". I reinstalled the app and checked my LTE connection (30 Mbps).
Also, I sometimes have 2 or 3 of the same category listed (e.g. Engine)
Any thoughts?
Any thoughts?
#23
Mine does that also, just hit the circle button I believe it is on the bottom task bar to go back to home screen, then go back into OBD and it should be loaded. Must be a bug in the app. Anytime it’s taking too long to load something that trick seems to work. I have duplicate control units listed as well, doesn’t affect anything.
#24
By the way once you make this change it only works when you manually push the camera button. When the car defaults to camera view on its own it will still shut off at 5-6mph.
#26
I think I originally entered 32 km/h (since 32 km/h is roughly the same as 20mph) and it accepted it. But when I looked in my history on the app it showed up as 30 km/h for new value that’s why I posted the coding that way. Try 32.
#27
Great to know this is available!!
I have an older amazon tablet, I think I can get Android running on it. Is it safe to assume that this works over Wifi?
Also I have an older wifi OBD2 reader from Amazon that worked with my BMW. Would that work with this software? Or am I forced to get the OBDEleven unit?
#28
#30
@jrjunior31 So I have tried this a few times, but now with the latest update to the app A5 has a red circle. When I click on it, it says connection timeout every time.
