'93 quattro 100cs overheating
I hope this is the right format.
First timer here and iqnorant about cars but a frustrated Audi owner. The car has been overheating and in the shop twice in the last 6 months. I had the head gasket, water pump (twice), thermostat and reservoir cap replaced. Fan seems to run fine and no leaks discovered during pressure tests.Yet I will be driving only a short distance when the inside heat turns cold, temp climbs and water/antifreeze spews out the overflow. Mechanic says "keep water in it" which is obvious but unless I have the cap on so tight I can't budge it in order to top it off(yes, I'm wimpy) the water will pour out in just a few blocks. Running the air on high seems to bring temp down and heat comes back. Now mechanic says "sell car". Any other suggestions?
nick greene-killam
02-09-2017 05:05 PM
Max_A6
12
06-21-2005 04:52 PM
quattro90S6
26
05-27-2004 09:30 PM
