94 100cs 2.8 keeps blowing head gaskets
trying to figure out why head gaskets keep blowing this is 3rd time is not overheating at last time heads were shaved and they were straight,scince then i replaced right side head and gasket, then bout 6mos later left side went again prob all started when cust fans was not working that was cause of 1st head gasket replacement but it runs great otherwise is it possible the block is warped?!? any help would be appreciated thanks
what kind of coolant?
is it audi coolant?how is "not hot"?describe the temperature. so you are doing it your self? do you resurface the heads? and when you did the job did you do both head gaskets?new bolts? the mating surfaces need to be extremely clean, with no added silicones and what not.
ever run it with radiator cleaning chemicals, or too much water in the mix that lead to corosion??there are alot of things, we just need to know exactly how you carried out the proceders.
Re: what kind of coolant?
new head bolts,coolant,cleanserface even refaced cyl head been working on audi for 2yrs been working on nothing but german cars for over 20 yrs did everything right but still prob????
would it be odd if i had the same problem..
mine were replaced only 40,000m ago.. granted thats not last week, but one of mine started leaking the other day.. regardless im not happy about this and im gonna have to do some work in the next week or two!
did you blow both sides or just one?
when I did my car 2 years ago (T-belt snapped) I got a bad set of gaskets. shortly after the rebuild I blew the passanger side, then a few months later the drivers side went. now for the last year it's been fine. all in all both sides went in about 10k miles from the rebuild. I just concluded it was a bad set of gaskets since each side went and not the same side 2x. just for curiosity do you recall the brand of gaskets you got?
same as i did, lost one at a time!
I got a deal on a gasket kit first time around, next time i got higher quality gaskets. did you by chance use the same kind of gaskets on the re-do? hopefully not!!!
