95A6 Mirror glass delaminated-how to replace
Both of me sideview mirrors have brown around the edges. To replace them do you just pull them out of the housing or is it more complicated? Also, anyone know of a cheap source for the replacements?
Re: 95A6 Mirror glass delaminated-how to replace
I need to replace mine, too. The procedure as I understand it, is to tilt the mirror all the way up and then pry it out with something flat. It's held on by clips that should release. Also, check before you order if you have heated mirrors. Heated mirrors have a plug on the back.
Not sure on the best place to order mirrors. Haven't really looked, yet.
Best regards,
Travis<ul><li><a href="https://forums.audiworld.com/a6100/msgs/5449.phtml">thread on the mirror</a></li></ul>
Best regards,
Careful.with mirror.. (edit for accidental empty post) -more-
I broke the gimbal that the mirror is attached to- If it's like my 96 I think you have to try to push that mount slightly=- I cAn't quite explain- but I don't reccommend just prying the mirror- slide a spatula up behind the mirror THEN pull it of the mount that it snaps in to...
gtreng1
04-25-2008 08:24 PM
90mtl
09-26-2007 06:13 AM
