austinado16, HELP!!
My fans both worked, but the driver's side one had a bad shaft at the fan end = major wobble/rattle
I tried to repair the gouged out shaft with epoxy putty. Was a cool idea, but didn't last. I just replaced the fan the other day while doing the crankshaft seal job.
Find out why yours aren't working before you replace them.
The switch in the radiator is what triggers them, so make sure that hasn't failed.......by unplugging the plug-in going to it and then jumping the terminals in the plug-in. Fans should come on. If not, check for 12v at the plug-in. IF no 12v, work backward up the harness and find out where you're losing the voltage at.
lbarrett
New Member Welcome Area
11-03-2017 10:35 AM
S4ortified
08-22-2006 02:49 PM
Rsingh7
Audi 100 / A6 (C4 Platform)
12-11-2004 09:56 AM
qbauer
05-26-2002 05:45 PM
