Auto Transmission Gear box Jerking
My C4 was facing jerking during gear change,already replace the ATF and filter...how to dismantle and carry out valve body electrical and mechanical inspection,Pls provide me some guidance ..Thanks all Audist !
What kind of ATF was put in?
Was it a recommended type, i.e. Pentosin ATF1 or a Dexron II? Was the fluid level confirmed to be full. Should fill with engine running and up to temperature. Fluid should start running out the port. If there's not quite enough fluid in there, it will jerk on shifting.
mmmm....valve body
taking the valve body out is no big deal.
<img src="http://i47.photobucket.com/albums/f174/DavesData2/1999%20Audi%20A4%20Quattro/trans/DSCN4554.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket">
<img src="http://i47.photobucket.com/albums/f174/DavesData2/1999%20Audi%20A4%20Quattro/trans/DSCN4556.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket">
but you do need a Bentley repair manual to show you which bolts to remove and which not to touch.
The real question is, what leads you to suspect the valve body? The $70 you'd spend on a repair manual could save you lots of time and $$ by showing you the procedure for testing and troubleshooting your transmission (and all the other problems you've been posting about.)<ul><li><a href="http://www.bentleypublishers.com/product.htm?code=ac45">http://www.bentleypublishers.com/product.htm?code=ac45</a</li></ul>
wisconsin_quat
01-19-2004 05:15 AM
Karpedmman
16
12-21-2003 09:13 AM
adambalgach
12-03-2001 05:13 PM
