CEL and VAG error code
Old Dec 14, 2005 | 07:08 PM
urs6_ma's Avatar
Default CEL and VAG error code
Has anyone seen this before:
17819 - Secondary Air Injection System: Bank 2: Insufficient Flow P1411 -92-100 - Unknown Error Elaboration
I cleared the code, have not run the engine again to see if it reappears.
Patient is a '96 A6.
Thanks!
Lee
Old Dec 14, 2005 | 10:34 PM
A6Gary's Avatar
Default Per Bentley Manual §H 01-143, six possible causes for DTC 17819....
1. No vacuum or vacuum too low on mechanical combination valves => Check connecting lines & vac reservoir for correct routing and leaks...
2. Leak or obstruction in vac hose between combination valve and sec air injection solenoid valve -N112- => Check connecting hose for leaks and obstruction.
3. Connecting hose from air filter to sec air pump plugged => Check connecting hose for leaks & obstruction.
4. Wiring connection between sec air injection pump relay -J299- & sec air injection pump motor -V101- faulty or -V101- faulty.
5. Secondary air pump frozen.
6. Both combination valves faulty.
Old Dec 15, 2005 | 04:29 AM
urs6_ma's Avatar
Default Thanks!
Hadn't gotten to the Bently yet, didn't actually think of looking...I was just going to call my mechanic in the am.
Since it could be as simple as a hose, I think I'll poke around a bit.
The light didn't go back on this morning, so maybe it was a single incident...
We'll see.
Thanks again for doing the research...
Lee
Old Dec 19, 2005 | 07:15 AM
urs6_ma's Avatar
Default It's Back!
Light's back on today. Time to go see what needs fixing...
Lee
®ob
Oct 20, 2018 04:50 PM
tangfolio
Mar 27, 2008 06:10 AM
007TT
Apr 24, 2006 12:28 PM
sethicus1
Feb 18, 2004 11:45 AM
