chirping noise
Old 02-05-2015, 12:49 PM
Eric Johnson's Avatar
Default chirping noise
Hello,
New owner of a 1992 100 Wagon. Getting a chirping noise at roughly 25 mph, roughly 1800 rpm. Doesn't start until then. If I take the car out of gear and coast, no noise. If the car is idling in neutral, and I rev it, no noise. If I put the car in gear with parking brake and pedal brake and rev it, no noise. Thanks for any help you can give! -- Eric.
Old 02-05-2015, 06:34 PM
egp320i's Avatar
This would suggest it's drivetrain related. Possible cause, CV joints or the brake system.
At 25mph vibration due to worn brake rotors could be hitting the metal splash guards.
Least you can rule out a bad transmission if you can rev it in neutral and not hear any noises.
Is the chirping rhythmic in nature? if so it's something rotating.
Old 02-19-2015, 11:01 AM
One
One's Avatar
I wonder if that is the same chirping i get....It is related to the blower motor and changes with engine load. It gets worse the higher the engine load and blower motor speed. Only starts after the fan has been on for a while and mostly in summer. I run the blower motor the same speed in winter also... It come out of the air vents.
soguy12
Q7 MKII Discussion
27
01-24-2018 03:52 AM
Skyler@Achtuning.com
12
07-23-2008 05:33 AM
RBfatality
Brakes Discussion
12-05-2007 04:52 PM
Ed@mtl
Canadian Discussion
07-22-2007 01:50 PM
86audi4000csquattro
04-18-2005 09:07 AM
Quick Reply: chirping noise
