Climate Control Problems
Audi's A/C system is designed not to come on when the temperature falls below ~37deg F. If the climate control is registering a temperatue of -34, then the A/C will not come on.
If the problem turns out to be the sensor then swapping in a new sensor should do the trick!
HTH and Good Luck!!
