Code 17509 Oxigen Sensor Lambda low voltage?
Old May 13, 2006 | 09:25 AM
ltooz_a6_a8_q7's Avatar
Default Code 17509 Oxigen Sensor Lambda low voltage?
Hello all,
What can be done with the check engine light oxigen sensor lambda low volage? Replacing all oxigen sensors? Where do we get these inexpensively? After market?
Thanks,
Old May 13, 2006 | 11:10 PM
A6Gary's Avatar
Default DTC 17509 means either O2 Sensor G39 faulty (bank 1, front) OR an air leak. Check for air leaks...
first since that is the cheapest and most likely cause. If you require a new O2 sensor, check on-line suppliers, such as www.autohausaz.com, www.partspalace.com, etc. You'll find a list of these sellers under the FAQs.
Old May 13, 2006 | 11:17 PM
Default Re: DTC 17509 means either O2 Sensor G39 faulty (bank 1, front) OR an air leak. Check for air leaks
Air leaks in what area? hoses? tubes? Where is bank 1, front left or right?
Thanks,
Old May 14, 2006 | 08:48 PM
A6Gary's Avatar
Air leaks in the intake manifold system & associated connections. Bank 1 is right side.
Old May 14, 2006 | 09:35 PM
Default Re: Air leaks in the intake manifold system & associated connections. Bank 1 is right side.
Thanks Gary, I'll look into it, the check engine light has not come back for a few days now.
catalyst
VAG-COM Discussion
May 30, 2005 04:01 PM
jeffs00TT
Mar 7, 2005 02:35 PM
Pitcha23
Sep 15, 2004 07:20 AM
5000turboman
Jul 30, 2004 12:56 PM
Matt E.
Jun 19, 2002 05:36 PM
