cold air intake
cold air intake
does anyone know an availible cold air intake kit that would fit a 1992 100. I attempted to install the after market cone but had a temp sensor problem. I could use anything at this point anything will help me
There are many possibilities...search the 12v forum
For modifications to the stock intake, check out Mr. D's setup...or you could get a proper cone setup so that it doesnt throw an error ;o
It's amazing, well worth the money...
Mance does an incredible job...I had definate performance gains from the TB alone, and even better performance once I got rid of the bulky restrictive airbox and flexhose. Let me know if you have plans on an intake hose kit, I can tell you exactly what to buy, as Mance's hose kit is no longer available.
second.
K&N oil will affect MAF sensor.
You will increase risk of sucking up water and destroing engine.
Besides I have measured temperature inside the motor compartment - it is almost the same as outside.
If you want to spend some money - get better tires (or separate winter/summer tires) or brakes.
