Coolant Leak
I peak underneath and I can see fluid dripping near the transmission pan. Maybe near the metallic pipes.
This means the plastic belly pan is dry all the time.
I have been telling the mechanic that I have been losing coolant...but he kept saying pan is dry. He can't see any leak.
Also the coolant smell and leaks are only after driving the car around.
Any input ???
and the car is driven around...I can smell coolant outside the car and see it drip next to the transmission fluid pan....after the coolant level has lowered...the leak slows down...
Same with smell,when coolant level has lowered...smell is also less frequent....
In my case, I can see the coolant leaking from the radiator for awhile when it's up to normal operating temp, as you describe, after I top off the coolant reservoir.
Stop leak would likely work for awhile, but I'm hesitant to use that junk in a good Audi motor and cooling system. I'm planning on replacing the radiator soon.
