Door locks gone haywire!
Any suggestions for a fix would be much appreciated!
To check, open your hatch and pull the boot back from the hatch to expose the wires. You'll probably see a mess of cracked insulation and several wires touching. To fix, you'll need to take off the interior trim in that corner and possibly the hatch depending on where the cracking is. I had enough slack (like an extra foot) in the wiring harness by rerouting it a bit on the inside that I didn't have to use any extra wire. Get out the solder and heat shrinking because there are something like 15 wires, all small gauge, and there's not enough room to put wiring splicers on all of them. Once the wires were all together I coated them with dialectric grease to prevent the wires freom binding, pulled the slack back into the body and put it back together.
