heater and leaking coolant problems!
Old Sep 13, 2008 | 10:04 AM
blue100cs's Avatar
New Member
Default heater and leaking coolant problems!
Hello all, I just pick up this 100cs couple days ago..current problems: No heater or a/c from the vent but motor blow normal air. also when the engine running hot, sometimes it leak coolant from the back of the engine (previous record from mechanic showed there is a leak hoses from the manifold). can you guys point out where is this hose locate? also this morning, I let the engine warm up and turn the heater to HI level to see where is the leak spot. No sight of the leak (I guess the engine not hot enough yet) but a heard a squeeking sound (like air escape thru water or tide spot) from the motor box near the windsheld wipper. I noticed there is 2 hoses line running thru the motor. I tought the top hose, it was cold but the 2nd hose was a little warmer..is this mean the coolant being block from running to the heater core? any advice or suggestion the heater problem and a/c issue? thanks
joshwebs10
Aug 28, 2017 07:40 PM
TheChenga
Nov 30, 2012 09:25 PM
wotseurba
Audi 100 / A6 (C4 Platform)
9
Jun 23, 2008 08:01 PM
gregp1962
Dec 20, 2006 08:46 AM
95A6Q
May 16, 2006 06:14 PM
