coolant problems
1. Inspect the cap, if its not releasing the pressure then they are cheap to replace
2. Check the small bleed back hose to the reservoir tank is not blocked.
3. bleed any air out of the system at the engine bleed screw and the return heater hose.
4. turn the heater on full and check that the thermostat is actually opening up and you get hot coolant on the heater return hose.
