Help with strange problem
Thanks in advance.
But, you're getting weird "warning" icons just going down the road, and then it dies on you for no reason. To me, that spells ignition switch failure.
They're about $35 at the dealer, and you only want to buy the real switch, from a dealer. The aftermarket switches fail fast. Takes about 30min to install, via the opening where the instrument cluster is located. Details are in the FAQ's.
Electrical - Ignition system - Ignition lock - Ignition switch - $76.32 ($54.95)
Electrical - Ignition system - Ignition switch - no price listed (have to call)
Steering column - Steering column assembly - Lock housing - W/ignition switch - $124.95 ($89.82)
Steering column - Steering column assembly - Ignition switch - $35.03 ($25.22)
At these prices it's a no-brainer that I'll pop in a new one -- but which one? Thanks again!
