How hard to replace cam seals?
Old Mar 5, 2004 | 08:00 AM
Mark - Steve's bro''s Avatar
New Member
Default How hard to replace cam seals?
What's the procedure to do this, if I might ask...
Mark.
Old Mar 5, 2004 | 11:41 AM
jschick's Avatar
Default front or rears? rears easy fronts hard.
I just changed the rears, which one was a seal and the other was just a o-ring just pop of the covers and replace figure a hr or so, but the fronts are a different story, you need to remove timming belt and replace. remove sprockets to get to seals, or if you don't want to remove sprockets then you need to remove cams to get the seals off. should be done when you do timming belt, since you are not supposed to re-tension the belt.
Old Mar 5, 2004 | 12:20 PM
Mark's Brother's Avatar
Default Dont you need a sprocket holder tool?
I thought you needed a tool to hold the sprocket. Since Mark will be doing the Timimg belt with me and I have an extra set of seals that I can give him, can this be done without the cam holding tool? Would all we have to do is mark where the sprocket is positioned on the cam, loosen and remove the sprocket r&r the seal then tighten the sprocket down in the correct position?
Old Mar 5, 2004 | 01:32 PM
New Member
Worth doing just the rears? or will front want to leak, then?
Old Mar 21, 2022 | 08:58 AM
jda's Avatar
jda
Is seal the same front and rear?
Old Apr 7, 2022 | 10:37 PM
egp320i's Avatar
Banned
front seals go around the shaft thus the cam sprockets need to be pulled to press them in, this is generally done when you do the timing belt job since you are already there.
Old Sep 15, 2022 | 11:31 AM
jda's Avatar
jda
Just had the left rear done; (seal behind) cam sensor (was leaking) All done fixed
checkpoint
A4 (B8 Platform) Discussion
Nov 10, 2015 01:26 PM
live2tune
Nov 26, 2012 10:41 AM
turbosquatt
12
Jan 27, 2009 09:39 AM
S4gasm (LoTR)
Mar 25, 2007 12:47 PM
JacobB
9
Jun 13, 2004 08:13 AM
