hrmm..
hrmm..
I know this is not the forum for this but I would just like some help... I just tested my cousins 2000 golf gti 1.8t and here are some error codes it came up with... (Her CEL is not on, but I would still like to know what some of these mean?) Help is appreciated:
Address 01 -------------------------------------------------------
Controller: 06A 906 032 CM
Component: 1.8l 5V 110kW TLG V004
Coding: 06530
Shop #: WSC 00000
3 Faults Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 17 -------------------------------------------------------
Controller: 1J0 920 900 K
Component: A4-KOMBIINSTR. VDO V23
Coding: 07242
Shop #: WSC 01317
IMMO-IDENTNR: VWZ7Z0X2113109
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Coding: 06530
Shop #: WSC 00000
3 Faults Found:
Coding: 07242
Shop #: WSC 01317
1 Fault Found:
Probable caue of misfires is bad MAF. Check the air flow mass rate at wide open throttle...
(do this in 2nd gear on freeway). The mass flowrate should be 80% of your engine HP, e.g. 150 HP = 0.8(150) = 120 g/sec. The coolant sensor G2 is also probably bad. I had the exact same problems on my wife's VW Passay w/ the 1.8L engine. New MAF (replaced under warranty) and a new coolant sensor fixed the problems.
LOOB'ER'GOOD
06-07-2013 08:25 AM
