Ignition Fault ? 100/92'
Every time I turn off the ignition, after about 15 seconds all auxillery power stops (ie I loose power to clock,radio etc) Has anyone experienced this problem or can help me ? Al
Re: Sounds like the ignition switch has failed. It is a common fault, do a search.
Yeah cheers Edd, have replaced ignition switch and still no change! Also when I turn off the ignition and close the drivers door I lose all power !!
Check the battery connections. If it is under the rear seat....
..ours (UK) are at the back of the engine bay but I have heard of problems with the seat touching the top of the battery and other poor connection problems.
MXHowes
04-28-2009 05:26 AM
junkyardjedi
Audi 100 / A6 (C4 Platform)
02-09-2007 02:06 PM
