Ipod and Gamma (xpost)
This is 13pin connector. We have 8 pin connector. Search this forum (or A8 forum).
There is a nice article about hooking up directly to the head unit. BTW, if you find this article, please add it to the FAQ bellow. Thanks.
Installed MP3 player...NeoJukebox
with the delta bose I had to tap into the CD changer harness. There is no easy fix, a casette converter or an FM modulator. I have the CD player, so I tapped into the cd plug and put in a double pole/double throw relay on the L and R speaker wires from the CD changer. When the Neo is turned on, the relay cuts the CD L and R imputs and switches to the neo L and R imputs (to switch the relay I pulled switched power off the neo fm modulator port), I also placed a relay on the neo power from the switched power to the CD changer. So when the HU goes on, the neo has power, but if the neo is switched off, the CD plays. The Cd player must be present, but does not need to be turned on or have a cd cartridge in it. For info on Neo, check the link.<ul><li><a href="http://www.ssiamerica.com">http://www.ssiamerica.com</a</li></ul>
beep-beep
Audi 100 / A6 (C4 Platform)
05-30-2004 02:35 PM
NAUGHTTY
9
12-03-2003 05:26 AM
Any way to wire IPOD input through CD changer wire? Seems like it would be easier than splicing into
DirtyVegasTT
10-13-2003 08:05 AM
E-Ticket
09-03-2000 08:34 PM
