Need a CD player/changer
I recently (Aug) purchased a slightly abused 95 A6Q and I'm slowly fixing up the few minor problems that it has (mostly trim pieces and maintenance). I absolutely hate driving this thing for two reasons:
1) Rough idle/hesitation. I've checked all hoses and now Im doing the Chevron fuel system cleaner bit before spending some real money and
2)More importantly, it deosn't have a cd cahnger. I am assuming that it was destroyed in the accident this car was in. Whatever the reason, this bugs the crap outta me. I need a CD changer and I want ot buy a used/refurbished unit (some currently on ebay) but I don't know which model will work with this car.
In a nutshell, anone know where I can can find out which part number will work? I need the site to be in English (mono-lingual American here). I'd prefer to avoid the dealer. They want me to buy a new changer, harness, and install kit totalling over $1000. Hell, gimme a grand and 3 hours at tweeter and I'll get the whole system replaced. I just want to keep everything like it is, spend <$200 for a changer, and be able to drive this without going insane.
Thanks,
EH
Thanks,
EH
Re: Need a CD player/changer
Ok, i have the same problem as you. I will give you a few pointers on hesitation rough idle. Inspect/replace the fuel filter, spark plus, wires, ISV valve, throttle body area for air leakage, CATS/exaust system, and also check the air tube from the MAF to the intake plenum (mine had a gap by the seal and was leaking presious air. Also don't use the injector cleaner that is put in the gas tank. I would have an Indy Lube or a uero car shop flush your injection system, it is many times more powerful and only costs like $40-50. It drives me nuts dealing with the vibs and hesitation, it's meanly when it gets cold out when i feel the most hesitation.
Here is a helpful link for ya!
https://forums.audiworld.com/a6100/msgs/13434.phtml
Good Luck
Good Luck
Re: also oxygen sensors
Definately o2 sensors, i found an air leak in a intake hose where it connects to the intake plenum. Made a huge differance in performance, look for the little stuff first.
heres some cd changer info....
http://www.ibiblio.org/tkan/audi/radios/
that link will give you most all info needed to find a cd changer.. and www.car-parts.com may be able to get one in your area used...
Ray Khan
12-29-2005 10:54 AM
A4Dorty
06-17-2005 07:36 AM
4taz
09-01-2004 05:33 PM
skabaru
11-11-2001 11:14 AM
