POWER steering leak
POWER steering leak
i have a leak in my power steering..ive traced all the hoses and they seem to be in good shape.. all the clamps are tight.. its coming from somewher down near the radiator i believe.. on the drivers side , bottom .. anyone have any ideas for my to try b4 i drain it all and replace the hoses?
is it leaking about near the oil filter area?
look at the hose transition and verify that there are no fluid residue/dirt buildup. There is a fluid cooling line connection going under the radiator(return line) and another to the pump(engine area). Could be just a loose connection(good) or damaged hose($$$).
I have added more clamps(screw-tight) as the original crimp clamps were not that tight anymore. On my '97, had a leak first on my reservoir(fixed that), then hose connection(above,fixed that), then on my rack itself(grrrr!will have it replaced).
Hope it's just the connections needed to be clamped. Good luck.
Andy_FL
09-25-2016 11:58 AM
quattromano
01-03-2003 05:09 AM
