Problem with lights and alarm lock for 92 100 Q
When i lock all my doors earlier i was hearing a small beep indicating car is locked.recently its not beeping and also my lights. interior lights if any one door is not locked or closed it should glow .. my light setting are adjusted for that. But its not glowing . if i go for long ride some times it does.. but normally it doesn't glow. can any one suggest the solution.
Re: Problem with lights and alarm lock for 92 100 Q
Check the soor sensors to see if all of them are operating properly.. as for the beeping for the alarm im not sure. Try setting the alarm off.. leave one of the windoes open and lock it and try to open it from the inside .. see if the horn sounds when you set it off..
Snuckley
05-29-2006 08:35 PM
maxintosh
10-16-2000 11:47 AM
