Tailgate Trim Fixed-Still Noisy
Using info here I removed the tailgate trim on my A6 Avant. Took the car for a ride with the trim off. Tailgate still squeaks like crazy. Put it all back together with epoxy, metal strips etc. Nothing is moving on the trim. Tailgate still squeaks on very slightly bumpy pavement. Is there a way to adjust the tailgate movement so this won't happen?
Do you think the lock mechanism itself is loose, causing the door to rattle? Hmmm...I'm
not sure you can adjust the stops on the locking mechanism, I looked at it to try and line up my tail lights better, seemed un-doable but maybe someone here has a secret to share.
Re: Tailgate Trim Fixed-Still Noisy
I fixed the squeaking!. I wrapped some rubber tubing and glued it around the bars that the tailgate latches grab. There was some thin rubber there, but it was mostly worn away. Now the gate itself doesn't squeak, and I had already fixed all the trim that was loose.
EF99
S4 (B8 Platform) Discussion
08-21-2012 07:26 PM
Mirror|rorriM
Auto Detailing Discussion
09-18-2008 09:03 AM
tusca
04-17-2005 05:40 PM
