What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
#13
i know that the one in the UrS will work, but do you know what type of scews...
they are that hold it in? I've tried alen keys and they don't seem to fit even 1.5mm ones. BEntly just says "remove scews"...duh
#15
OK...the ignition switch was kinda broken...
the tip that goes into the back of the key lock was cracked from the spring inside. I took off that white cap and noticed the internal center piece was crooked and one contact was stuck under the center spining thing. So i took the one out of a UrS that i have and it was still good, but i had to beat on one of the wings, since the screw was stripped/not moving. SO then i made sure they were the same, they were, except for thier internals, that spining part that moves the contacts up and down. So i swapped everything put it back to geather as i would have seen fit. BUt no i get no check engine light, but now im getting a readyness error talking about the K-line, ignition not on, wrong data port, those things. NOw im pretty sure i put the internal spin pices the right way b/c it onoy goes one way when matched up to the key mechanism area and the lower contact parts. So no what the hell is wrong?? THanks guys a ton
#16
ok no i put the UrS back into its original housing and now im back to square one agian...
VAG is working same code coming up, but the ignition is smoother so it was kinda messed up but if the real problem, no clue. Going to go for a drive later at night to see if the light will stay off. ANd tomorrow ill play with the ECM and what not, i hope i dont have to go hunting for wires now for the three S's
#18
ehh, it was broken, but that was not the problem...
took back the carpet under the dash on pass side, and yup...water damage. The B connecter which is red was corroded and several of the contacts were to, but mainly the Red power wire was totally corroded from its gold finger on the ECM where it corroded enough to fully separate from the ECM. Junk yard tomorrow to grab one out of a 1997 A6 avant...hopefully its wires/contacts are good. Going to take one of the 5 blank clips that are inside the Red connecter and resplice one to the Red wire so that i don't have to go splicing and replacing a ton of wire.
#19
when we got that message at the shop for the 1000th time
we put our vag com unit down....:'( it brought tears to my eyes. seriously our vag com unit S#it the bed and kept saying that we use the computer version now.
audi2.7audi
07-25-2007 12:48 AM
03AR2rescu
Audi allroad
03-12-2007 10:42 AM
boehm781
VAG-COM Discussion
08-05-2005 01:19 PM
boehm781
07-15-2005 02:06 PM
