Windshield Squirters lost Pressure
My windshield squirters are not pressurised anymore. Does anyone have a diagram of how the system works and goes together so I can try to fix it.
Much appreciated in advance....
Ok, here is what I got..
<img src="http://packet.hypermart.net/audi/washer/pic_one.gif">
number 19 - is the pressure cylinder. Probably what you need to replace. Its either that or the pump, item 10. But if you are getting fluid out, no pressure, its probably the cylinders.
<img src="http://packet.hypermart.net/audi/washer/pic_two.gif">
To Remove / Install
(This is located at the headlight washer area)
- Snap off cover -A- by hand.
- Pull out cylinder to stop.
- Clamp washer hose.
- Remove spray jet -B- by carefully pulling and turning.
<img src="http://packet.hypermart.net/audi/washer/pic_three.gif">
- Remove hose clamp -A- and washer hose.
- Remove bolts -B-.
Tightening torque: 3.5 Nm (31 in lb)
- Remove nut -C-.
Tightening torque: 9.5 Nm (84 in lb)
- Pull off spacer -D- toward front.
- Remove pressure cylinder toward rear.
Install all components in reverse order of removal.
To Remove / Install
- Remove bolts -B-.
- Remove nut -C-.
Type44Q
06-08-2003 06:45 AM
