1.8 Turbo 20V
It needs some work....
You will need the correct mounts and block along with a radiator setup from a FWD 4-cyl 4000, details are at the link. One thing that is not clarified at that link is mating the engine with the 016 transmission in the 4kq, you might have to swap in a later TORSEN unit or source a 4-cyl quattro transmission from a european Audi 80q. Plus you would likely have to go custom with the clutch and flywheel.<ul><li><a href="http://forums.vwvortex.com/zerothread?id=1774571">1.8T swap</a></li></ul>
Cush
01-13-2006 08:56 PM
a420v
01-23-2003 09:18 AM
audiboy_17
27
05-22-2002 06:30 PM
