86 Audi Coupe GT wont start cold
Still when it sits for 6+ hours, it will fire, stall, fire stall, fire stall, fire, run horrible, grey black smoke, missing, chugging, backfiring through the intake, somtimes stall. Only for maybe, 30 seconds, a good rev up will clear it out.
It used to be way worse before i did these things. It would have to be throttled barley running untill it had 3-4 minutes of running then its perfectly fine.
One thing is, the hose from the idle stabilizer to the intake, has the Air shrouded fuel injector supply hose broken. and sealed off. Would this have any kind of effect on this?
What about vacuum leaks in general? I'd do a smoke test, either with a machine or blown from a cheap cigar from the gas station. That's the easiest way to tell if it's leaking anywhere.
-Rog
if the valve is working correctly you can do what the PO did on mine coupe, connect the cold start valve power wire to the starter solenoid, that way when you start the car you will get the extra gas needed to get her to start.......
After working on my Audi I think I have seen about every hotch botch Band-Aid there is to be had...
