Aggressive Camber???
Depends (as both a garment and a comment)
2 is a lot for a straight street car unless you live on a mountain road. I run 1.5 for a dual purpose car and I get no weird wear at all. It sure is a lot of fun.
I have found with the 4kq, that you can make up considerably for the understeer with all the camber range.
Thanks for the input.
I was also think that 2 is a bit too much, although the car isn't my daily driver.
I'm going to go down to 1.5 and watch the tires.
BTW, what are you using for tires/wheels?
I have 15x7" with 205/55 Kuhmos.
Thanks,
Carlos.
Thanks,
Carlos.
Unscientific test for you...
The reason why I use 1.5 deg is that I feel the car is now pretty neutral and I don't get any odd wear up front. If you put too much static neg camber then the car is twitchy in the straights.
KärcherK
14
07-17-2008 12:15 PM
Going in for alignment I have the K-Mac kit on the fronts now..just checking on some good aligment..
M3KILR
14
03-03-2005 09:19 PM
BluDemon
12-01-2004 08:47 AM
meem
03-03-2004 05:18 AM
S4 Vince
16
10-10-2002 01:09 PM
