Anybody in northern MN need control arm bushings done before I move to Florida?
Made a tool that lets me do them on the car.. -more-
kind of like the tools for doing wheel bearings on the car, only much smaller.. I remove the two bolts at the control arm pivot point and lower the inner end, remove/insert bushings, and then bolt it back up. (only tighten slightly - you don't want to torque the control arm bolts up to correct specs until you have the car resting back with it's weight on the wheels) It's hard to get the torque wrench under the car so I usually drive it two blocks to the drive-on lift at a muffler shop. Best time so far is 1:05, worst was 1:25 for all four corners.. There is a tool at Huw Powell's site made out of plumbing pipe that would be similar. (search for "Huw's Audi Garage" on Google.com)
ill take ya there and we can play. u can have the spare bedroom if u need a pit stop on your trip as long as u dont mind cats, weve got four...oh and a snake (6' red tail boa)...an a lizard too
ThaboTheWuff
04-26-2015 01:43 PM
dragon-ryder
13
10-31-2005 10:18 AM
try2diy
09-10-2004 05:58 AM
Mr Paul [T-28]
06-28-2004 04:38 PM
