Clutch pedal height adjustment?
As my car's pedals sit right now the clutch pedal sits a good 2 inches below the brake pedal... I'd like it a lot more of the pedal had more travel. Can anyone tell me how to adjust the pedal so it sits at the same height as the brake pedal or even a little higher?
Thanks in advance!
Richard
Thanks in advance!
Richard
Should be a bolt or something
Look at where the clutch master cylinder rod meets up with the clutch pedal, its threaded. You can adjust the height here. Ive never personally done it, but thats how its done.
STFA: It would appear my slave and master cyl's are going out...
Even though they've been replaced in the past 5 years or so. (My brother claims that he re did both of them but I don't know about that....)
My car is exibiting the same symptoms as <a href="https://forums.audiworld.com/4000/msgs/15008.phtml">This thread.</a>
You guys are AMAZING!!! I just needed to ajust the pedal!
Not only does my clutch feel exquisite, it also catches up high like it should. AND my cruise control now works because the sensor on the clutch now knows that the clutch is all the way up. It only took me about 15 mins too! AMAZING!!!
Thanks again guys!!!
I've been fixing lot's of stuff lately
Drivers side window regulator.
Brake light.
Speedometer.
Clutch pedal.
Passengers side window switch.
If my boredum keeps up much longer I'm going to have the most functional 4kq on the boards. :-P
Brake light.
Speedometer.
Clutch pedal.
JayP
10
02-17-2008 01:01 PM
ButchHusky
11-16-2005 10:25 AM
