coolant flush - 4KS
Before i put it in, i would like to flush all the old coolant out. its a grimmy mix of water and anti freeze and it reaks like fish...So basically i just want to know how you guys would go about doing it and any tips of cleaning the internals in any way
So, if you want to get crazy...
First you want to flush with a detergent. Dishwasher powder is about the best because it doesn't foam up but it cuts grease. Use about a cup mixed in a gallon jug of water. Drain the old coolant and fill it with this, adding more water to fill the cooling system.
Then you just drive the car around for awhile. I don't think you can really leave it in there too long, but a single trip is sufficient. Drain it and flush with plain water.
That will do a pretty good job on its own, but it's also a good prep before doing an acid flush. You can either buy a commercial product (I know Mercedes dealers carry it, not sure about VW), or you can make your own with citric acid powder. Stores that carry a lot of vitamins and tofu-based foods will sell it.
For your engine size I would use maybe half a cup. Less is better than too much. Mix that with a gallon of water and do the same procedure as with the detergent, EXCEPT you don't want to leave it in for more than 15 minutes or so, and I would also not run it through your heater core, since those are pretty delicate. Just let the engine run for a few seconds to circulate it, shut it off and let it sit for the 15 minutes. You don't want the engine to get hot at all. Then drain, flushing thoroughly with water.
The acid will definitely leave it squeaky clean and get rid of any junk that has built up.
Now the important part: Don't refill it with green antifreeze. It's hard to get the G11/G12 stuff, so I've been using G05, which is the best substitute you'll likely find. You can get it from Amazon.com (not .ca though), but parts stores sometimes carry it or can get it.
If you do fill it with green you'll have to drain and flush it every year or you'll start to get buildup again. I'm convinced that a lot of the cooling problems with these cars is due to many years of green coolant, which nobody ever flushes. With G11/12 and G05 you don't have to flush it every year. I believe they're rated for 3-5 years but they're not going to plug everything up if you miss that schedule.
If you don't want to get crazy...
I would just run clean water through a few heat cycles, then do a parts store flush (like Prestone), more water, and then refill, again avoiding green coolant if you can.
Regardless, remember to let the engine cool before draining and don't add cold water/coolant to a hot engine (both can cause cracking or warping).
-Rog
For now, I'm not sure if I can get a new thermostat. How much are they usually at a parts store?
Anyway, that's not a big deal, it just saves time. It's pretty much a must if you do the acid flush, but otherwise you'll just have to run it until the thermostat opens.
-Rog
be careful on those 6mm bolts that hold the housing down--they bust off easily. soak the heck out of them with Liquid wrench. be sure to spend some time cleaning out the fill bottle. it has baffles and screens and it takes a lot of time to clean all the gunk out of it. I ended up replacing my top hose with a nice rigid silicone one from 034 motorsports. Mine had gotten soft and was collapsing at the top bend when it got hot. they have a whole silicone hose kit if you want to replace all of them
Use what ever antifreeze you can get, but keep up on regular changes if you use the green. All I know is with the green I see sludge, with G05 I don't...
-Rog
So as far as i know, things seem good inside. Im running it with just water for now until i get my new coolant sensor.
The sensors effects are so annoying. I cant even start the car from cold anymore. I have to unplug it, start the car without the sensor. (i guess the ecu figures the engine is cold?) so then it fires up good and i have to plug in the sensor again while its running and constantly hold the throttle down just a tad until its warm enough to keep itself on its closed loop thing.
anyway, im going to pick up that sensor soon and then look at a good resourse for the required anti freeze
any idea if Borg Warner is any good? it has to be for the price im paying for it...
-Rog
To resurrect an old thread... Can we assume that G05 can be mixed with G11 then?
Edit: Ok, follow up question. What is the pink stuff? I thought it was G11, but depending where I read, people are saying G11 is blue, and G12 is red or purple?? o.O
Sounds like G11 is silicated and G12/G05 are not? So G05 can be mixed with G12, but not G11?
Anyway, all the G12 I've seen is pink and G11 is blue, although they go by different designations depending on the brand and car manufacturer.
Here's a useful article about coolant to answer your other questions:
https://blog.fcpeuro.com/how-to-pick...t-for-your-car
If you scroll down it has a section about what can and can't be mixed.
