how does the fuel gauge sender come out of the tank?
ive been giving it taps with the screw driver but barely turns. like maybe a degree or two per round of pounding.
if your lucky, a quick fix
Are you sure that you need to take the sender out. i had a problem with the gauge to. first check the resistance through the positive connection to a ground some where else. if there is a little resistance that means the sender is working, but the wirering is bad. i just fixed my fuel gage and that was my problem but luckily only the ground wire was broken. all i had to do was splice a ground to a nut in my trunk, and it was fixed.
k4r1m
05-20-2011 06:38 AM
AlwaysAudi
12v V6 Discussion
09-26-2006 09:13 AM
So last Friday my fuel gauge gradually stopped working until yesterday it was dead completely, until
Mr.D-'97 A4q 12v
12v V6 Discussion
09-16-2003 07:33 AM
Bobby Kinstle
05-11-2003 11:50 AM
