intermittent fuel injector issues
Old Feb 19, 2003 | 07:15 PM
paulpas's Avatar
Default intermittent fuel injector issues
I have a 86 4kq with a rough running engine. The engine idles rough, not too rough, and when you give it throttle the engine sputters until rpms get to about 3000. At those RPMs it smoothes out.
My mechanic (who no longer has a job for the shop is closing at the end of the month) noticed that injector 3 and 4 were not firing, then at high rpms it started to. He said either those injectors are bad, or my fuel distributor is bad. Injectors are cheap, fuel distributors are not. Which do you guys speculate? I'm in the process of finding a new mechanic to work on it. However, the more info I can get the better.
Old Feb 19, 2003 | 08:22 PM
Chris in VA's Avatar
Junior Member
Default Speculation
My thoughts...run a couple things of Techron through your gas tank and see what happens. The fuel injectors are constantly on, so I doubt they're at fault. How did he determine the injectors were 'not firing'?
Old Feb 19, 2003 | 09:01 PM
Audi[VW]EuRo_StYLe]'s Avatar
New Member
Default The price depends if used or new....
new injectors for an 86 Golf are $70 Can a piece.
And a new fuel distributer is just not necessary. Get a used one. If you get used injectors, it may be a risk, because the condition is hard to tell by just looking at them.
I would first chack the spray patern on all of them, they should have a nice even spary (not squirt). Then try a fuel injector cleaner, which you dump in to your gas tank.
Old Feb 20, 2003 | 10:10 AM
QCRAZY's Avatar
Swap injectors with a "good cylinder" and see the problem follows!!
Old Feb 21, 2003 | 03:20 PM
paulpas's Avatar
Default Re: Speculation
At idle he removed the plug wires one by one to notice of the engine ran differently. When he removes plug 3 and 4 the engine did not change at all, but when he removed 1,2 or 5 it sputtered. Right now I have severe lack of power. I had already ran a **** of tecron through it, it helped, but not so much. I did see an earlier post from someone w/ similar problems, and new plug wires fixed it. I ordered some to see what happens, but if not, I found a place to get new injectors for ~$30ea. I'm going to hold on on the fuel distributor, I don't see how that would fail honestly.
B8aruba
A4 (B8 Platform) Discussion
Mar 20, 2010 09:45 PM
JoeD_KC
Audi 100 / A6 (C4 Platform)
Jan 14, 2009 09:46 AM
Big Hank
RS4 (B7 Platform) Discussion
26
Feb 28, 2007 12:08 PM
neuroptic
Sep 28, 2003 03:30 PM
pwhatley
Jul 22, 2003 10:08 PM
