The Dreaded Fuel Dilution Issue
For now, let's assume that it is a real issue.
Is it worse to run the engine at high RPM's or low RPM's?
ie: is more fuel getting by if the engine is lugging or wide open?
Worst to best: Repeated Cold Start, Idling, Sitting in Traffic, WOT, Lugging , Cruising.
Fuel dilution under normal operation is proportional to the torque the engine is producing. At startup and low RPMS (like idle) more fuel blows by and/or washes down the cylinder wall.
I would say cold and WOT...
cold, the fuel isn't vaporizing optimally. WOT is a no-brainer, IMO...it's why your gas mileage plummets. More fuel is being used and some of that doesn't burn in combustion and get's by into oil.
wondering how someone can lug an RS4 with the 6 gears...
i know you can lug it if you're trying, but shouldn't be a problem. therefore, how it figures into fuel dilution is questionable, IMO.
