Looking to buy 1984 Audi Quattro 4000 S and 1986 q 5000
#23
Neglected isn't the word for this. Lmao. I'm looking forward to the build for this too. it wont by anything like rog is planning on doing. but ill try to make sure and post up what ive done/doing.. ive never done one before so it shall be interesting.
#24
I haven't done one either so I'll be losing my virginity too. :P
I plan on doing it as clean as possible. I've got most of the URQ bits needed so I should have no big issues.
#25
I'm going to avoid using URQ and other parts as much as possible. i want to retain a lot of the stock parts from both cars. limited swap budget...
#27
That looks like the perfect car to get the engine from.
-Rog
#28
The non-turbo got the NF, which is a 2.3L. It's another one you can put in the 4kq to some benefit, though not as much as a turbo for sure. It's roughly equivalent in power to the KH (2.14L), which was the early turbo engine.
-Rog
-Rog
it is indeed the perfect car.
#30
If I remember correctly, that sound is the compressor stalling because they didn't have a BPV/BOV. There's probably a reason they did it that way, but it's definitely hard on the turbo.
Since CIS is a closed system from the airbox to the exhaust, it doesn't like when air exits prematurely, such as with a straight BOV. So, if you want some sound, you'll have to look into what's called a 50/50 or hybrid BOV. It recirculates half the air like a BPV and then lets the rest out. I hear that if the car is tuned perfectly you can run a straight BOV with no ill effects, but otherwise the engine can stall when you let off because it's venting too much air that's already been measured.
I'm trying a 50/50 valve myself. I think the sound is an easy way to tell how the system is behaving, but I'm hoping the 50/50 will be a lot less obnoxious. Of course mine doesn't have any "whistlers" or amplification, so there's that too. Personal preference.
-Rog
-Rog
