My 1985 4000 turbo quattro project
#222
I am positive that the harness stuff is hooked up correctly. I did figure out that long, long ago I had just installed the distributor without regard for timing, just to get it out of the trunk. And even though that would have caused it not to start, correcting it wasn't the magic pill.
It seems to have a fueling problem, although I am getting fuel at the distributor and wet injectors so it's not so bad as no pressure at all. The gas in the car is 3-4 years old, so there's that. But I did drain a fair amount when I installed the new fuel pump, plus put in a couple gallons of fresh. It almost wants to start. In fact it did for about two seconds. I'm hoping the injectors are just gummy or something.
I did have one more trip of the breaker today, so that confirms to me that 150A is barely enough, though I'm sure it would be okay for everyday use.
-Rog
#223
Little bit of an update... If it sits for several hours or overnight it'll idle for 10-20 seconds. Both times it did this I tried to give it a little throttle and it died immediately. However, the other day it started and I was able to rev it a couple times. Every time since it does not like throttle.
So I'm hoping it's just gunked up. I did crack all the injector lines at the distributor and all but two had fuel come out. So I shot some carb cleaner here and there, even taking the metering head off and freeing up the plunger. Now we're getting to more times when it'll fire for at least a couple seconds, and less time that I have to let it sit before it will start. Seems like maybe the sticky old fuel is slowly making its way out.
When it does run it builds good vacuum, spark is there on all cylinders, et cetera, so I'm pretty confident in it being fuel related. Hopefully most of you will be doing this in the space of a few days or a month and not years and you'll already be driving at this stage instead of flushing out glue.
-Rog
-Rog
#224
Hmm, okay, so I got one of the long idles out of it and decided to just let it go for awhile. Then I tried a little throttle and...
So we're getting there. Still sounds a bit like Sebulba's podracer though...
-Rog
-Rog
#225
Since that video, I rearranged some vacuum lines and made sure they were all tight, and now it starts consistently. Slowly the old fuel seems to be clearing out. I also dumped in a bunch of Lucas oil, which claims to neutralize old gas, and that seems to be doing its job.
But it looks like I have some bleeding to do with the clutch, as it engages the instant the pedal comes up 1/4". And of course some extra heat shielding and various bits of bodywork...
-Rog
-Rog
#227
Oookay, so I discovered that even though the ECU controls the timing (which means you can turn the distributor all you want while it's running and the timing will stay the same), if the distributor is off enough, it (the ECU I'm guessing) won't give spark or fuel when you try to start it.
So, if you're having problems along those lines, make sure your distributor timing is correct.
-Rog
-Rog
#228
The clutch is working well enough that I was able to get it turned around in the driveway. First time I've gotten to see it straight on from the front...
I'll probably have to get my pressure bleeding setup out to get the clutch working like it should. Fingers crossed that's all it is.
-Rog
-Rog
#230
Shouldn't be too long. Of course I'm not looking forward to the $100 penalty when I get it registered, since it hasn't been on the road in four years...
Full steam ahead with my shaved spoiler and deleted taillight center section. All holes welded:
-Rog
-Rog
