Where's a good place to get SS grill mesh? I need it for...
Lowes, look for a meshed Gutter cover, 5 sheets for under $10.00, unless you want to spend about
$25.00 then ask Advanced Auto, they have this stuff too, larger size sheets if you need it that way.
The Lowes meshed gutter grill is slightly pre-bent but works great, can't beat that for the money, and it's fine meshed, not these big holes ;-)
She is running like a charm, thanks for asking. Trying to fit 01 Golf GTI rear calipers on her...
Lightweight low cost stuff, can't resist that ;-)
The Calipers will be upside-down installed but surely an improvement.
Very much indeed, but the mounting direction is up-side down, meaning the E-brake cable would run
to the lower end instead to the top as the stock setup. Also the brake lines will have a bit larger diameter but I'll post pics when it's done. These darn Banjo fittings are a small fortune ;-)
