will borbet 6Jx14H2 fit a coupe?
looking at a set of borbet used wheels. the only code on them is 6Jx14H2 anyone know if these would fit the coupe bolt pattern?
Not enough info...
You'd need to know the offset. Its pretty easy to figure out the bolt pattern - If your coupe uses 4x108, the holes will measure 4 1/4 inches from bolt center opposite bolt center. If you need 4x100, you'll measure 4 inches exact. The next value is offset. Borbets tend to run +35 or +38 offset for FWD models, Audi's run +45 for 14 inch wheels. A good start is to ask what car he had them on (model and year) - that's a good way to find out the bolt pattern and whether you should expect a FWD positive offset. (+38s should work on Coupes- the rims will just be 1/4 closer to the fender...
mktt
Wheels & Tires Discussion
06-09-2009 12:26 PM
big_anthoiny
03-20-2004 07:34 PM
Jo2
10-24-2002 09:59 AM
$teady$upreme
08-04-2002 10:59 PM
