***200 20V now Bucking at 4k RPMS and only reaching 1.1-1.2bar of boost...
Old Feb 16, 2006 | 08:49 AM
  #11
jurq's Avatar
Default I agree with Tom. Sounds like a boost leak. Check the IC, etc as well...
And, if the flywheel ref sensor or flywheel itself were bad, your symptoms would be reversed-stumbling at low RPMs and smoother running at higher ones.
Old Feb 16, 2006 | 09:57 AM
  #12
Blake@NWAutoSalon's Avatar
I replaced my plugs with OEM replacements, which should work perfectly...
Old Feb 16, 2006 | 09:58 AM
  #13
Thats going to be next on my list, I swear. Thats what I thought all along after reading the boards.
Old Feb 16, 2006 | 10:08 AM
  #14
Any steps to testing yourself, or would I best be to go take it to a mechanic?
Old Feb 16, 2006 | 10:09 AM
  #15
I did replace the MM hose with a Samco replacement.
Old Feb 16, 2006 | 10:11 AM
  #16
My intercooler is not strapped, but I will look into it this weekend.
Old Feb 16, 2006 | 10:27 AM
  #17
4Driver4's Avatar
Tech Guru
Tech Guru
Default You need a source for compressed air regulated down to 15-18 psi...
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/29825.phtml">Teh archives</a></li></ul>
Old Feb 16, 2006 | 10:45 AM
  #18
audiman4's Avatar
Default Everything I've ever seen says only use the F5pdr's.
Any of the audi gurus...SJM, IA, Lehmann, etc will tell you the same thing.
Old Feb 16, 2006 | 01:37 PM
  #19
Default and you could pressurize the system up to the 15PSI if you had a pressure tester correct?
Somehow I think I could put a valvestem on that 3" piece and have the same effect and just use a tire pressure gauge :-)
Old Feb 16, 2006 | 04:00 PM
  #20
4Driver4's Avatar
Tech Guru
Tech Guru
Yes. Don't go more than 15 to start.
