1990 3.6 v8 oil leak question
What is the switch on the back of the block, passenger side, underneath the distributor cap that is prone to leaking, and does anyone have a replacement part number for that?
Thank you,
Rein
Thank you,
Rein
I think he's talking about the distributor. The g62 coolant temp sensor for the ecu would leak coolant not oil. If that is the case there isn't a seal for the hall sender but there are o-rings for the flange seals on the distributor.
01S8
14
01-19-2014 10:30 PM
covertforces
12-15-2005 01:32 PM
rs2audi
09-10-2003 09:13 AM
