'91 100 rough engine shut off
Old May 13, 2012 | 06:08 PM
samanthac02's Avatar
Default '91 100 rough engine shut off
my 1991 Audi 100 is shutting off rough, not every time, and I don't know why. I turn the key, remove it and the engine rumbles out one or two more revolutions then stops, reminds me of stalling a standard. It doesn't happen all the time and I can't seem to find any correlations to anything when it does happen.
Only other problems I'm having are needs a new IAC valve, rough/idle and dies and it's starting to look like I need a new alternator, starting hard and dash lights getting dimmer.
Could it be the IAC valve too, is it normal for this model, something more sinister?
This is my first Audi and I'm loving it
Thanks for your responses!
Old May 13, 2012 | 07:46 PM
yodasfro's Avatar
The running on after shut down you are describing is known as dieseling.
It could be caused by a leaking fuel injector or injectors. The injectors could also be contributing to your idling problem. It could also be the ISV as described try unplugging it and see if the car still does the same thing. You can clean the idle stabilizer valve(ISV)with carb cleaner and then lubricate it with WD-40. You should also check all the hoses for vacuum leaks. The staring hard could also be the fuel injectors. A tune up, new plugs >wires> cap> and rotor may be helpful too. Dash lights getting dimmer hard to say what you are describing. But if they are flickering it could be the voltage regulator in the alt. much cheaper than a whole new alternator. Of course make sure the belt is good tight and check to see if it is charging with a multimeter.
Old May 14, 2012 | 05:07 AM
Kneale Brownson's Avatar
Tech Guru
Check alternator output at both the front and the battery. You COULD have a corroded "splice" in the line from front to back. Splice is under the carpeting in the passenger footwell.
I use throttle body cleaner on ISVs. It includes the lube you'd get by using brake cleaner and following up with WD40.
Old May 15, 2012 | 10:04 AM
I had already cleaned the IAC valve with carburetor cleaner and tested it unplugged but hadn't lubed it with WD-40 so I did that this morning and checked the alternator, it's putting out a pretty weak charge but the belt seems good. I think I'll take care of these two problems and then look into the fuel injectors.
Thanks for the responses, I had no ideas about what would be making it shut off rough and now I have somewhere to start.
Old May 15, 2012 | 10:30 AM
one5k's Avatar
i had a bad ignition switch causing a similar issue. when i pulled it out it was cracked
quattro4ks
Inline-5 Discussion
Sep 15, 2010 04:08 PM
sidespar
14
Aug 28, 2004 11:23 AM
will4468
Apr 14, 2003 07:59 AM
EdP
Jan 6, 2001 06:45 AM
T. Henry
Misc. Models Discussion
May 17, 2000 08:11 PM
