91 Audi 100 driver side lock off track
Does anyone know how to remove the door panel and put the lock back on track? I got locked out of my car yesterday because my lock is stuck under the panel and automatically locks the doors. Someone please help if you can. Thanks
if the vacuum pump is constantly locking the doors, just unplug it(it's under the seat) then you should be able to get the door open, remove all the screws that hold the panel on, carefully break all the clips around the edge of the panel, remove the panel, damage all the wiring connectors in a fit of anger, then you can get to adjusting the lock rods
Unhook the vacuum pump elec conn under the rear seat (next to battery). You may (or may not?) be able to take a pick or something small and push/wiggle the lock **** into alignment with the hole. Then, pull the pass side lock up (with pump connected). Easier said then done, but worth a shot. If you can get the lock **** up, take it off the shaft (turn until loose, pull up) and reposition it a tad higher.
Eric
Eric
slightly disgruntled
09-07-2006 11:15 AM
