After I chipped it w/ QLCC, I believe I might be running alittle lean..
I can smell a oder of exhuast now, but maybe its a small leak in the exhuast pipe since that was replaced also.
There is an adjustment on the fuel distributer.
The adjustment hole is on the back of the distributer near the air intake boot.
It will accept a 3mm allen hex.
Turning it clockwise makes the mixture richer, turning it counter clockwise makes the mixture lean...
Turn it in very small increments. 1/8 of a turn will do at a time. Even the smallest turn can make a big difference...
I highly suggest you have someone with the proper tools do it for you...
You will need a ohmeter and a C0 annalyzer to correctly adjust the mixture.
I had my duty cycle set at 43-45%
Steve
Michigan
Steve
Michigan
MikekiM@PureMS
03-03-2004 10:21 AM
Air conditioner smells not good...how to fix it? it only smells when just turn on, then after someti
NvFlw
02-06-2004 12:20 PM
CooliceTTT
04-20-2002 01:40 PM
