Anyone know the part # for high-pessure steering hose?
The car is a '91 200 TQA 20V
After shopping around, I've run into two part #'s. they are as follows:
VWW019586
M2021-20465
Both pics are identical, yet one is typically $100 higher in price.....Any thoughts?
Thanks!
VWW019586
M2021-20465
Thanks!
If those are both from worldpac vendors
One has the damper tube in it and the other doesn't. There is a damper tube in the OEM hose that quiets the pump considerably. Without the damper, there will be a buzz/hum when turning the steering wheel.
Napa sells a hose for the 5k style crush washer fitting'd hoses for $25 that has a lifetime warranty and has the damper. I haven't used it, so YMMV.
If you can find a hydraulic repair shop, generally they can rebuild your hose for anywhere between $25 and $100 depending on where you take it, the day of the week, whether the stars are in order, etc.
HTH!
HTH!
jurq
10-13-2008 05:32 PM
Nor
07-31-2008 05:52 AM
VR_Life
Audi Original "S" Cars
06-14-2008 02:19 PM
quattrotto
06-01-2005 05:27 PM
