Anything special about changing the windshield washer pump?
Yea, that's for sure, clear hose seems............
to turn brown at the nipple from engine heat, then act like shrink tubing. You will probably need to use a knife to cut it off. I have always replaced tubing sections with black rubber hose, ID is the same to fit washer pump nipple, though it is larger in OD, so won't fit under the Audi OEM tie downs. Works just fine though.
TTacous
16
03-16-2009 09:30 AM
ianbis
06-20-2002 07:31 PM
