birdmanmt---TPS
birdmanmt---TPS
<center><img src="http://pictureposter.audiworld.com/49179/dsc00145.jpg"></center><p>Jeff, will either of these work? None of the 'stangs had throttles left. They all looked the same from tempo (4cyl), to tuarus (v6) to tbird (v6). Part #s are E7AF 98989 AC 8L21A and F3DF 98989 BA 2J19B. If you can use them let me know and I'll send them out. $2 each is all they charged me.
No 5000 in the whole yard. Waah.
Re: birdmanmt---TPS
i'm not sure if they will. They're not the same as the one off the stang i used to have. What does the other side look like? Three wire? Can you put them up to your throttle switch on your car and see how close they are to fitting?
Thanks Tim
Jeff
Thanks Tim
Jeff
Re: birdmanmt---TPS
<center><img src="http://pictureposter.audiworld.com/49179/dsc00147.jpg"></center><p>Yeah, they're three wire. I think they could be rigged with a small adapter plate. If you don't want these it's cool. I can get my 4 bucks back next time I go out to check for new Audis.
Re: birdmanmt---TPS
Hey tim-
I think i'd give the one on the left in the second picture a try. Looks close. On the underside there it looks a lot like the one i was looking for. In your opinion, which is closest to the audi one? I know their both pretty far off on the mounting holes, but what about the center hole for the shaft? Which one is closer there?
email me
birdmanmt@juno.com
Jeff
email me
birdmanmt@juno.com
Jeff
Re: birdmanmt---TPS
hey i just noticed your in spokane? I get up that way from bozeman every now and again to the racetrack....motorcycles! Ton of FUN! I'll have to let you know the next time i'm going that way.
Thanks again
jeff
Thanks again
jeff
Re: birdmanmt---TPS
Just buy both from him, you can't go wrong with a $4 price tag plus shipping. He took time to go to the yard for you. JUst my opinion, not trying to be rude;-)
Re: birdmanmt---TPS
I've been looking around for similar stuff for MSing my Jag. What I was looking at was the 65mm throttle body/TPS (buy them as a pair) off of some of the later model Fords with the 4.6L V8. They're plentiful and cheap in junkyards and on eBay.
Just a suggestion, not sure if it would work for you or not.
-Ted
'82 Jaguar XJ-S -- 5.3L V12
-Ted
CvTech
04-20-2006 07:28 AM
michaelandashley704
07-19-2004 08:36 AM
Bracketracer
47
08-16-2001 04:27 AM
