Can I bleed the brake booster? '90 200q
I've blown the same O-ring on my hydraulic pump several times, this time I seem to have lost brake boost after repairing & refilling. The reservoir ran empty, but it's done this before without this problem. I'm guessing air in the line somewhere between the pump, bomb, and boost. I see the line from the boost to the reservoir, is there flow or some passing of fluid as the brake is used? If so, I suspect it'll work it's way out if I run it a bit. The bomb has been dead for at least 200k, I don't think that'll be the problem.
I have pump seal kit from Holland Imports minus two seals, that didn't work for my car....
I suspect that it was for the 5000/200 pump. You can have that if needed, also if you need some help bleeding it I can stop by tomorrow night.
Jim Bush
Holland, MI
Jim Bush
Holland, MI
habe Ich gesagt
Audi 100 / A6 (C4 Platform)
9
04-27-2007 08:33 AM
parkpy
Audi Original "S" Cars
07-26-2005 05:30 AM
