can someone help with wire diagram decipher?
I am trying to take an aux. instrument cluster (oil pressure, temp, volt) and install it in a Vanagon that received an NF swap. Looking at page 429 (1991 100) in volume three, I am trying to determine what P1 and T1 are. Seems that they are the same- only from either side of the dimmer control (the one on track 261)? The dimmer thingy on track 253 is confusing me â€" is this circuitry that is on board the aux inst. board? I guess Iâ€<sup>TM</sup>m confused why there would be two lines from the dimmer when the ground track is already taken care of....? Or am I missing something (likely!)
Any input appreciated!
Thanks
Thanks
For the '87/88 5kcs
there are 3 connections to the Instrument Panel Lite Dimmer. (3/P1-BL, 2/P2-BL/Y, 1/P3-BL/W) All three connect to the Instrument Lite Booster(29,30). It is hard to tell exactly what the set up is from the wiring diagram but it looks to me like the Dimmer is supplied power and ground from the Booster. The third line provides the Booster with the signal to determine the brightness. That's just a guess.
COMPUTEK::WMS
03-12-2007 04:26 PM
M3=Lunnch
06-05-2006 07:27 PM
Twisted5000
10-09-2004 03:18 AM
SiV6Qcoupe
09-11-2003 02:04 PM
